  New Posts New Posts RSS Feed - Alternative version of WSX (plan)
Amano View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amano Quote  Post ReplyReply Direct Link To This Post Topic: Alternative version of WSX (plan)
    Posted: 27 January 2010 at 7:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amano Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2010 at 7:59pm
same horn path, same response... smaller.. easier
Quantum Sounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Quantum Sounds Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2010 at 8:51pm
nice one anano
should have a better responce higher as the bends are kept around 90deg rather than 2 180's
Saul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saul Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2010 at 9:45pm
20mm difference between the two - was it worth the effort?
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2010 at 2:52am
I like it
WSX made simple not simpler
FlipC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FlipC Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2010 at 5:48am
OK
Trying to get my head around this layout. So would the access hatch be from the front inside the mouth? With driver firing through the section that is 144mm?
If so where would you personally run the wiring?
I ask as that grey part which would be on what I think would be the access panel looks like a connector.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amano Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2010 at 6:45am
Originally posted by FlipC FlipC wrote:
OK
This is a Heat Exchanger.
Access hatch is at the front of..
144x378mm is an original WSX throat area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amano Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2010 at 6:53am
yup, it was! Smile
this version hasn't parts having angles less than 45deg except for throat part... two ones
hatch is parallel to driver bottom to make heat exchanger
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amano Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2010 at 6:56am
Originally posted by Quantum Sounds Quantum Sounds wrote:
nice one anano
it shouldn't have big changes in response... maybe less distortion
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2010 at 9:30am
Looks like a good alternative to the often requested CV B36 types too.
djk
tomschute View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomschute Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2010 at 9:56am
Good effort - again Clap
@ FlipC
easy, just run wiring straight through the centre panel through to the back panel
@ Amano
width...?
Edited by tomschute - 28 January 2010 at 9:57am
www.stableaudio.co.uk
Speaker Building Services
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amano Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2010 at 10:09am
@ FlipC
@ Amano
width...?
574mm as in original
